More Tips
Shark413
Shark413's Avatar
More Tips - 06.13.2009, 08:11 PM
Tip #10
If you use the Losi battery tray this is a must. Add a strip of 3M Dual Lock velcro to the bottom of the tray and to your battery. This and the battery straps will keep the battery from sliding forward under heavy impacts and breaking the front of the tray. Dual Lock is much better for this application because it has better shear strength than regular hook & loop velcro. Dual Lock will not move verticaly (shearing motion) where as hook & loop will give slightly which could cause tray damage.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
