Thread: 6s drop off
spcpicard
06.15.2009, 07:51 PM
A truggy on 3200 cells might be pushing the 30C rating depending on weight. And 3200mAh is not much runtime, but should be good for 10-12 minutes based on a 300w average power draw.
What LVC point are you using?
And as far as the rotor seperation of the Tekin motors, just think of it as having a slipper inside the motor.
3.5 volts/cell, the same I've always used, I was thinking it may be the lvc but seemed to be a little fast for 50%, now that I think about it though it does seem to change all of a sudden, would suck if I just bought the tekin when all I had to do was lower the LVC.
All the races I'll be in will be 10 min mains.
As far as weight I am thinking I am on the lighter side according to some nitro burners. Ready to hit the track weight is 9lbs 8oz with the heavier set of tires.
