glassdoctor
TEAM FUSION
glassdoctor's Avatar
06.16.2009, 02:20 PM
IMO a lot of the trouble with chinese deans is from the pins getting misaligned during soldering. The plastic gets soft and the pins can move pretty easy if you are not efficient with the solder job. If this doesn't happen, I think the fake plugs work pretty good... and are good especially for low power stuff like charge adapters.
But the real Deans Ultras are the best way to go, and they aren't THAT expensive, relative to many things in this hobby. Check out what we pay for similar things... like balance plug leads, etc.... those things should also be $.99 or less but they often cost 2-3 bucks each. Just another example...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
