Thread: 6s drop off
spcpicard
06.16.2009, 02:33 PM
Originally Posted by Patrick View Post
I wouldn't give up on the setup yet. Just change your LVC to about 3.2v per cell +or- .1v. Maybe go down to a 14t pinion or change to the losi 47 or 48t spur, and probably put the the tekin motor in. Your motor rpm is a little low, but it's still high enough to work well. Your packs have the same watt hours and watt output as a 4s 4800mah pack, so there's no reason they shouldn't work when geared for the same speed as the 4s setup. About 12 mins race runtime is about the most I would expect from them though. Once you've tried that stuff (especially the LVC) then decide about the setup.
Yeah I race with a 4s 4100 neu energy on a 1512 3d in my buggy (also on 3.5v/cell cutoff) and it has plenty of power the whole 10 min main, that's why I figured the 3200 6s would have just as much or more, of course the china cells in the neu batteries may have a one up on the enerland cells in the hyperions
