himalaya
himalaya's Avatar
06.18.2009, 07:01 AM
Shark do you have an idea to support the rear end of the motor? Losi's support fits only Losi's 39mm dia. Xcelorin motor, when use a CC Neu or Tekin(42mm), the Losi support will conflict with the motor can and thus have to be removed, leaving the motor hanging far on the mount. The worse thing is, the mount has only two screws to hold the motor, and the contact area covers only half of the front endbell, the 2 screws will take HUGE force when landing hard, also the screw holes of the front endbell might be stripped. (I was considering to purchase a RCM mount to replace the Losi)
As a temporary solution I applied some A+B epoxy resin mixed with cotton fiber between the rear endbell and the chassis. but when adjusting gear mesh the motor height changes, that drove me nuts.
Do you have an idea to better support the motor while keep the mesh adjustment easy(one of the few major advantage of Losi kit) ? Thanks.
....What a Blue Sky....
