skellyo
skellyo's Avatar
06.19.2009, 11:53 AM
what do you mean sean? they use a 12mm hex the pin length of size that holds the hex on doesnt matter, if you mean the axle size the b44 or b4 use a 3/16th (4.83mm) axle while the kyosho use a 5mm. either will work as the wheels center hole only sits on the threaded part which is slighty smaller diameter than the shank of the axle where the hex sits....
if you notice any difference between the two it woud be that the b4/b44 wheels would fit slighty tighter.
hope that made sense, (because ive used lazer wheels on a b44 and vice versa)
Since when do B4 wheels use a hex? That's certainly news to me.
