BP-Revo
BMW M Power!
BP-Revo's Avatar
06.19.2009, 01:37 PM
I just spent the better part of last night cramming a Neu 1112 into my 1/16 E-Revo. I haven't even ran the truck.
I'll be using a Mamba Max ESC in it and will be switching between 2S2P and 4S1P (I bought 2S 2200mah Zipp packs). I'll also be running a Castle BEC. Seems like overkill in a small truck but I guess this is what it takes to have a (extremely overly-) powerful setup that will run ice cool no matter what I throw at it.
I had to dremel the rear shock Tower and cut the shaft down on the motor (the Neu shaft was a solid 1/8" too long). I also ground a flat spot.
This weekend I hope to fab up the ESC mount (I'm going to make a mount out of aluminum that slides into the stock ESC mount tabs so I can slide my ESC out just like stock).
I've also moved my steering servo to the other side to balance the weight and provide cleaner wiring later on.
