sikeston34m
sikeston34m's Avatar
06.20.2009, 09:47 AM
Looks good Sike. I need to get some work done on my 0 turn as I have the motors now!
Thanks Linc.
I took the underside picture for you Linc. It shows the prop adapters.
In the pack of goodies that comes with the cutter head, choose a spacer that's too small, then drill the hole to fit the thread.
I also added a large pan washer and a lock washer. If this doesn't hold, I'm thinking Blue Loctite on the threads.
The Prop adapters are aluminum. I wish they were steel. But afterall, they do pull around some really large air planes. There is a fear of over-tightening for me here.
If there is a problem, Red Loctite between the Collet and shaft would lock it down. (And also make things really tough to disassemble)
Linc, I'm really looking forward to your zero turn mower. You may convince me to redo this one.
Are you going to use free floating swivel casters in the front, just like the big boys?
