06.21.2009, 08:42 PM
Your ,maxamps pack is good for about 60 amps, or 900 watts.
The neu pack should handle 120 amps, or 1400 watts.
I would go with the neu pack and the neu motor, but it is spinning a bit fast at 80k rpms. Good for a couple of speed runs, but not good to use till the pack dumps. The medusa on 3s will run cooler if you plan to play with it, but will not be as fast or powerful.
