Electric Dave
01.03.2006, 08:19 PM
Originally posted by coolhandcountry
I was going to race a 1930 10t against a feigao 8L. They seemed about the same speed and power. had same gearing on the trucks but the 8L was running 14 cells to my 12.
Ok, something here isn't adding up...if you check the "charts" the 1930/10 is 2090 k/v and the Feigao 8L is 3072 k/v. Do the math and you should see a theoretical RPM of 51609 for the 8L vs 30096 RPM for the 1930/10 - now if the gearing was the same I don't see how the 1930 could be about the same speed and power. Maybe the 1930 was quicker off the line but once moving the 8L should be much faster.
Oddly I want the 1930 to be a better choice here, I just wonder if you can explain why...
Thanks,
