Thread: 6s on M Monster
spcpicard
06.22.2009, 01:59 PM
Since both are switching BECs, I would expect either to be comparable efficiency-wise. If your goal is simply higher voltage to get the most out of your servo, then the CC BEC is gonna be the desired option. If you are worried about the CCBEC possibly failing (which generally means it will either output 0v or full battery voltage), then you could wire the system up so that the CCBEC only powers the servo, but the receiver and any other servos run directly off the ESC's BEC.
this actually sounds ideal, is there a easy way to do this?
