crazyjr
crazyjr's Avatar
01.03.2006, 10:55 PM
Thank you mike. And yes it does turn in better than the revo before. As far as handling compared to an Emaxx, i can only compare to a stock E, but it is way better in the suspension dept., more travel, more stability and more funand i haven't found a good setup. I'm only running the titans and a EVX and 12 cells and i can see the potential for nitro domination. Next step is a BL systemand good batteries (mine are junk)I'm leaning towards a 9XL with a warrior bk and a pair of scorpion 6400's should put it in the 35mph range and close to 40 min. run time. I don't want to break records, I want to play with nitro's and winand this chassis can do it. major props to Mike and Gorilla for making this truck a reality.
can only do one at a time but heres a few
