spiftacu1ar
06.23.2009, 02:16 PM
Also, to anyone interested, please understand these 2 things:
1) You will need to get ahold of your own custom length dogbones (as the output shaft is offcenter, and the gearbox is narrower than stock).
2) It is HIGHLY reccomendded that one use a skid plate under this. WHY? I designed this for my FLM tvp with skid plate, and I made the bottom pretty thin near where the spur goes in order to keep CG low as possible. (I may or may not make a version with a thick bottom for people not using skid plates)
UPDATE:
cahnged the parameters in the CAD to reflect the change in material. The new mass of the gearbox itself is approximately 102grams not including hardware (screws, etc). This mass also includes the included ESC deck.
