Ryu James
Ryu James's Avatar
06.24.2009, 02:34 PM
that Neu with the closed endbell and larger bearings sounds sweet. do the newest versions come like that normally now? how long did it take them to do the upgrade?
i would run the Neu for sure. the CC motors are good motors but for example if you take both your motors and hold the shaft you will notice that you can push the rotor on the CC motor in and out ever so slightly. the Neu will not do this. i just think the US assembled Neus are built to tighter tolerances. but you cant go wrong with either really.
Jammin SCRT10 Neu 1512 1y
