06.24.2009, 07:41 PM
If you are getting noticeably more runtime at 3.0 volts vs. 3.2 volts, your packs are not good enough. Good lipo packs with properly matched cells will stay strong, suddenly hit the cutoff and be done. At least for my packs, the voltage curve is so steep that there is really no difference in time between 3.0 volts vs. 3.2 volts per cell, so there is no reason to run 3.0 volts when you can run 3.2 volts.
