06.25.2009, 01:48 AM
Yah, you will never get that to the load (motor)... there is just too much voltage drop for a motor to suck the amps needed.
And what should also be noted, that even if you could charge at 15C rate, you won't be getting 1000+cycles from your pack.
These green packs, or a regular M1 A123 pack for that matter; should be considered a 15C/30C when comparing to your average lipo battery, performance wise. They can still handle the 30/60C ratings just fine however.
