06.26.2009, 09:45 AM
Originally Posted by Mentat View Post
Im using 48t/16t gearing and I ran 2 lipos packs thru (the engine has less then 1 hour total run time). First was a 4s1p 5000mah pack ran it out and the engine wasnt really all that hot.
If you did not have heat problems with that gearing and 4s lipo you should have the same results if you continue to run 4s lipo. No need to re-gear if your current gearing works fine. If you plan to run 5s again (and you say that you do not) You will need to put a smaller pinion on to adjust for the higher motor speed. I ran a lst on 5s with the 2200 motor and geared for 40 mph it did great. I am sure your motor is fine.
