Crt.5 brushless overheating
Jason
Exclamation Crt.5 brushless overheating - 06.27.2009, 01:17 PM
IM BACK FROM PLAYING FOR AROUND 10 TO 15MIN WITH MY CRT.5 AND THE TEMPS WAS :
177F ESC
157F MOTOR
100F BATTERY
IN A OUTSIDE TEMPERATURE OF 18 ºC = 64.4 ºF
I DRILLED HOLE IN THE WINDSHIELD..
I PUT THERMAL GREASE BETWEEN THE MOTOR MOUNT AND THE MOTOR ...
THE CENTER DIFF WAS FILLED WITH 120K FLUID..
NOTHING HELP !
SPECS WAS :
MAMBA MAX 1/10 ESC ( BEC ACTIVATED )
NEU 1509 2.5D 2700KV
13T PINION
46T SPUR
3S LIPO TRUERC 15C 6400MAH ( I TRIED A ZIPPY 3S 5000MAH 25C TOO )
SURE IM USING BIG TIRES AND BIG BATTERY ON MY CRT IT WEIGHT AROUND 6LBS..
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 13
Total Voltage: 11.1
Motor KV: 2700
Tire Diameter (inches): 4.72
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0082
Spur/Pinion Ratio: 3.54 : 1
Total Ratio: 11.5 : 1
Tire Circumference (inches): 14.83 inches (376.64 mm)
Total Motor Speed: 29970 RPM
Vehicle Speed: 36.59 mph (58.78 km/h)
Effective KV Value: 2700
KT constant: 0.5 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
