E-Sav v1
Nixpus
E-Sav v1 - 07.03.2009, 11:34 AM
Ok... hex hubs epoxyed into the rim.
This guy does standing back flips and wheelies at crazy speeds... Guess HW was right when they claimed the C4 combo to be crazy powerfull
It is currently in a version 1 state... it can drive but the motor mount + bat trays are plastic.
Hope this works.
Nixpus E-Savage v1:
Mortor mount v1:
ESC + motor mount:
Question time...
What is the strongest diff I can put into this guy? The one thats in there is quite tight and favours one of the wheels over the other.
Whats the best wheelie bar out there?
What type of slipper should I put into this guy? The standard either slips all the time (and then the plastic spur gear melts) or I tighten it all the way and it doesnt slip at all (at least I cant tell that it does)
What kind of wheels baloon less? The standard tyres I have atm is double size at top speed. And one of them is about to leave the rim. So even tho Ive used the calculator to gear for 45MPH... its much faster due to balooooooning.
I'll do a serious attempt at mounting the motor below the spur... its gotta be possible!! Will have to remove the motor mount of course. But I can make some other construction to stiffen the TVPs.
Name:	motor mount v1.jpg
ID:	7376   Click image for larger version
ID:	7377   Click image for larger version
Name:	esc + motor v1.jpg
