brushlessboy16
brushlessboy16's Avatar
07.03.2009, 09:04 PM
Originally Posted by pullinteef View Post
Yeah, I'd like to get a Tekin 2050kv, but trying to see what can be done with the 2D I've had for a while. It seems like when I gear down the motor gets hotter and it tops out too early on the straightaway. I already have timing and start power at lowest, don't like to turn up the punch control too much or I lose the ability to correct mid-air. Also, a buddy of mine smoked an RX-8, and he was told by tekin that part of the reason could've been that he was using the EPA at 80%.
thats total bull. changing you epa is equivelant to putting a foam block behind the trigger on your radio. All epa does is limit the max throttle percentage. if you set it to 50% its like holding the trigger half way from neutral to WOT
the signal the esc sees is that of the percentage of throttle.... I dont thhink the speed controller died because it didnt go full throttle....
on another note. i race with a guy who runs 3 rx8 systems, they run amazing, just as much power as the castle system- but the same guy blew the rotor in 2 of the 3 systems all in one day :(
