EDS
07.05.2009, 03:43 PM
Bulkheads and Chassis
First off today I cut the Bulkheads down so that the electronics and batteries could fit in.Before I cut them though I measured how far it was from the center of the Rocker post to the shock mounting hole. Then I got out the scroll saw and hacked away at the Bulkheads.
After I got those cut I finalized the chassis drawings. And taped them to the piece of 1/8th" 6061-T6 aluminum.
After a couple hours of cutting and filing I came out with this..
For cutting aluminum for the first time andonly having hand tools I think it came out good. But after cutting it I realized the parts where the front and rear of the chassis hook on are probably too thin. Unfortunately, I don't have material to make another one so this one will have to do for now until I get some 7075.Then I will put the diffs on risers so that the front and rear can be wider. I still have some more filing ,drilling,and bending to do but here is how it should turn out and how it looks right now.
This last picture is just to give you an idea of where the batteries will be going. Obviously they aren't going to be the actual packs that I will use. I plan on using some lipo 5000mah 7.4v packs.
Today I'm going to try to finish the chassis and mount the diffs. I will probably also start drawing the battery mounts and the shocks/chassis stiffeners too. Watch for updates. Actually I created a website for projects..
www.Teamkassanova.webs.com . There you will find all my projects and the latest updates on them (I will be posting updates first on my website)
Ethan
Team Kassanova
