07.07.2009, 04:19 PM
I don't know if you have LHS near you but if you do they should have a Piano wire/spring steel wire display ?
I buy the wire in the diameter of the pins I need and cut up a bunch to have as spares.
The wire depending on diameter is usually under a dollar for a 3' peice, Lots of pins !
