Finnster
KillaHurtz
Finnster's Avatar
07.07.2009, 09:15 PM
Originally Posted by Snipin_Willy View Post
My CRT.5 did the same thing with the breaks, even on the surface: tapping them locked up the wheels. You'll want to check the settings in the castle link and make sure you have forward w/ reverse lockout as the setting. If you're using it as just with reverse then I think the brakes lock as soon as you touch them (boat setting???). I'm not really sure if this is the problem, but it fixed my crt.5 brakes with the MM
hmmm.. my MM in my .5 has been doing the same thing. I'll have to check this.
