Serum
Serum's Avatar
01.07.2006, 09:34 PM
Lehner and BK are the same, as are the nemesis and the feigao's.
I can tell you that normally a lower KV setup on a higher voltage gets less hot. The Lehner motors (19/22 series) are very good. They don't get too hot if geared with sence.
I can't tell you anything from the kontronik or the aveox motors, but like i said before, the segmented kontronik motors would not surprise me, if they are the same quality as the lehners (also being segmented)
Promod is the one who does measure his setup, he uses an eagletree system for this.
I also read that you stated that the Xl size motors (feigao/wanderer/nemesis) are rated for 1200 watts. i've seen a calculation of another member, that said it was capable of pushing out 2200 watts at 92 percent efficiency. not bad at all imo.
I prefer a higher voltage setup, with a bigger low KV motor (such as an 2240 on 6-8S lipo.)
