07.12.2009, 06:05 PM
If I understand you correctly, you want to run 3s to one LBA10 and 4s to the other, both networked. I'm not positive, but I don't think you can do that. You'd be better off IMO to make an adaptor so the 7s pack is split into a 6s for the primary LBA, and 1s for the secondary LBA.
I can get it to balance wired as a 3s and 4s, just will not work in connection mode. I figure that if I cannot make this work I can physically split the pack into a 3s and 4s so that I can charge and balance them as a 3s and 4s and then wire back into series to run the drill. I figured that I cannot make it work if the pack is wired as a 7s, no matter what I do with wiring. I can use some powerpoles to do the connections, so it should work...
I know that a 720i would work... Bit 200 bucks for a charger that I do not need....
