Originally Posted by BrianG
So, you already have the pack split into 4s and 3s. OK, then make an adaptor to go from 3s+4s to 6s+1s. I'm sure this would work.
Not split as far as the 7 cells in series goes, just wired for a 4s and a 3s balance tap. I will try the 6s and 1s setup you suggest, but I still wonder if the outputs of the 2 lba balancers do not like being run into a series adapter... I think that may be my issue. I will report back, need to use the drill as it is fully charged now!
