07.12.2009, 10:07 PM
I'm on 62T Spur & 16T pinion now so I'm pretty undergeared now. I tried fitting a 17T one but the meshing causes the centre diff to bind. I can't create enough spacing between the spur & pinion. My only option would be to go on higher timing...
My qn: Since I'm undergeared, adjusting the timing to the higher values shouldn't bring my motor temps up, right?
