07.13.2009, 10:23 AM
Originally Posted by fastbaja5b View Post
Not sure what you're wanting, I charged the 5000mah pack at 1C on my balance charger, then hooked it up to the logger and another identical pack (no logger) on the otherside of the Savage Flux
Powered it up took it for a bash
Downloaded graph as above.
Was hoping some of you lipo gurus would have answers!
I am thinking maybe we need to set the LVC at 3.5v a cell to avoid these below 6v drops near the end of the cycle but before a 3.2v / cell cut off kicks in. Because as I said before, LVC did not kick in.
You said you did another run with the Reedy pack hooked up and produced a voltage of 5.89 under load, but you didnt post the graph for use to look at & determine the C rating, nor did you say what the load was that produced that voltage drop, thats what I was wanting. If you posted the graph elsewhere, then a link would be handy (my psychic powers arent what they used to be....).
