Finnster
KillaHurtz
Finnster's Avatar
07.13.2009, 04:32 PM
They are testing them in Slashes so far as I can tell. Pretty light duty.
30A could be ok if they are using small mah batts, like 2100 or less. Again, you should be able to draw parrallels from manufacturers, altho actually testing 5000mah cells would be the best (doesn't matter on cell count.)
Seems rather useless to test 35C 5000mah batts in a light 2wd with crummy traction to begin with.
"Hey, guess what, all the batts hold up well!"
--> N.S.Sherlock
