Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
07.14.2009, 12:19 AM
The number in a bearing you need to be smaller is the width (thickness), not the diameter numbers...bearings are sized like this: IDxODxW, and the ones you listed just have their ID (inside diameter) and OD (outside diameter) listed.
So, whatever the width of the problem bearing, just get one 1mm smaller...if the stock bearing is 5x11x5, get a 5x11x4. The hole in the transmission case where the bearing goes needs to be deeper, not larger in diameter.
-Chad
PM ME IF YOU HAVE THE BELOW:
