florianz
07.14.2009, 03:51 AM
hey,
thanks! yes, I was wondering, I think I have seen them once on an ofna. the tires are great. I realy like them, the're not that massive like truggy wheels, and the rubber is quite hard, which I like. nowadays the tires are so soft, no good for brushless, because it's like shaving the wheels... whith those wheels I have more ground clearence.
u just need some wheel hub extensions (eg. ofna) and I got myself some better foam, a bit bigger and harder then the ones inside. just go to a spezialised shop, which is selling foams and get it cut into the proper pieces. works great. when you glue the foam into one piece, cut the ends diagonally, then glue them.
I finally had to get some new wheels, the wheel-hub hex of on tire got "round". maybe I can fix it.
