florianz
07.14.2009, 06:45 AM
off-topic:
I wanted to "spice up" the cable & plugs of the motor, and I thought, well, I try 5,5mm bullet plugs. sh****t, the're massive
harr harr, that should be sufficient... w/ the original cables of the esc, the cables got quite warm after hard bashing. So I took 4mm cables, and it got less warm. I think w/ those 5,5mm plugs and the 6 mm˛ cables (between 9 and 10 awg) I should be on the safe side
I have the esc placed above the steering servo to have more weight on the front end (better steering, less wheelies etc.), so a bigger diameter makes sense.
flo
(aka Mr. Frankenstein)
