07.14.2009, 02:55 PM
You need a CNC mill to really get it done right... go to your local machinist...
you wouldn't really use a cnc to do clean up work like this. a mill, yes. CNC is computer numerically controlled- you wouldn't write a program for a CNC for one cut on a mill. There are CNC plasma cutters, water jets, mills and other things, CNC is just how they're controlled.
I imagine with my good carbide bit on my dremel I could add 1mm to a bearing hole. It would be easy to screw it up, but I'd try it.
