Originally Posted by Brian
my losi pinion wears alot too, not that much  but i have been kinda concerned. good know i can fix it  hey Mentat, just curious, but have the dogbone ends of your or anybody else's center drive shafts worn very much on the pins? especially the front one. i've only had mine for acouple month and if U look at the pin from the top, it looks like its nearly half gone. you can definitly see a gap between the outdrive cup and the pin. just curious if this is common aor what i should do to fix, grease maybe, idk. thanks
Yes the front center pin wears fast because of the angle it sits at. Mugen makes some nice pins you can use the repin the driveshaft with.
