Nixpus
07.16.2009, 03:42 AM
I have... but then I would have to increase the length of the wires between ESC & motor. But I guess your right
I had started to bend an alu mount for it. Was thinking to put it on top of the motor. But it will sit less protected up there and it will be annoying to fiddle with the motor if it sits up there.
If it becomes too nose heavy I can move the battery trays a bit backwards.
Epoxying the hex nuts didn't work btw... so now Im running with a pair of XL tyre/rims with the 17mm hex. Looks good so far. And bigger wheels = I can run in taller grass
Will see if I can get ½ an hour to mount the ESC properly and take a picture or two of the current state of the truck.
Cheers!
