Thread: medusa motors?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.19.2009, 08:38 PM
Either of those will do just fine. I would pick the 2200 cause it was close to what you had so your gearing would be about the same. However I'm not aware of what the gearing limitations are when running a Rustler with a 5mm shaft motor, you may not be able to gear as high or low as you want. This is where someone with experience with these would be of better help. Also consider the 50mm versions as they will push a Rustler without a problem as well! I have one on my CRT.5 and it's never been above 130*
