Thread: medusa motors?
sikeston34m
sikeston34m's Avatar
07.19.2009, 09:36 PM
Either of those will do just fine. I would pick the 2200 cause it was close to what you had so your gearing would be about the same. However I'm not aware of what the gearing limitations are when running a Rustler with a 5mm shaft motor, you may not be able to gear as high or low as you want. This is where someone with experience with these would be of better help. Also consider the 50mm versions as they will push a Rustler without a problem as well! I have one on my CRT.5 and it's never been above 130*
+1 on the 2200kv
Gearing on this with a 5mm shaft? Get the 40 tooth spur from a Nitro Revo. Then gear it up.
Go with the big tooth Mod 1 Pinion of your choice.
