a6m532
07.19.2009, 11:35 PM
Hi,
Has tried out the MGM TMM16025 in my flux. It seems to be much smoother than MMM at low speed. After repeated speed run with 4s and 6s on 22t pinion, the temperature of the heat sink seems to be lower than the plastic casing of the mmm when i touched them. Has measured a max continous current of 95 amps with a peak of 205 amps using the internal current sensor. It seems that 16025 would be a good replacement for the mmm in a flux.
