hemiblas
hemiblas's Avatar
07.21.2009, 11:20 AM
Something to do with the fact a 7xl can pull 100amps easy...
Those L motors can pull some serious amps when they are not geared properly. I figured an XL would pull the same or better as an L if it was geared for the same mph. I had the 7XL with 20/68 gearing on my emaxx which is what everyone was running the MM with on 4S. So ya the controller is not going to be as beefy as an MM and may not run the bigger motors, but waterproof it is.
