Ryu James
Ryu James's Avatar
07.21.2009, 05:46 PM
Originally Posted by KaztheMinotaur View Post
Center ring and pinion, gas tank, and upgrade kit gear plate.
I'm selling my LST2, 1515/1Y, and MMM now also.
I found these motor mounts. I might go with them.
http://www.southriverrcboats.com/sho...3DWRP-B-358%26
cool. i have seen those. OSE sells them too: http://www.offshoreelectrics.com/pro...jwr-mount-flat
you can get them for 15xx or 22xx series. i cant remember who tried them but someone here on the forum had tried them and said they werent the greatest but i think they should hold. it says the 22xx series mount is .33" thick.
i hope you get your stuff sold soon. i have so much stuff up for sale right now too. i am selling all those rampage parts i got on ebay. there was only a couple of things i needed.
so i just finished getting all the shocks done. now i have a complete set of Baja shocks on my Ramp. they are so smooth and supple. for the rear i just used a set of baja fronts straight up. for the fronts i had to cut about 12mm off the shock body and shaft. .then i made the shaft use e-clips to hold the piston instead of a nut. i think it will hold up. but i just love how these shocks feel with the petroleum oil instead of silicone.
baja shock shaft before:
redcat44
after modding:
redcat45
Photobucket
redcat42
had to grind away just a tiny bit of the a-arms on the front and rear for the baja shocks to freely move.
redcat41
redcat40
Jammin SCRT10 Neu 1512 1y
