Originally Posted by 6th
Nice setup, I'm sorry for asking this, but what modifications should be made to the chassis if any to mount the ESC and motor mount
no mods are needed for the conversion. the esc mount is on the battery tray of the losi conversion and i just secured my esc with velcro.
the only mod needed for the losi or RCM motor mount is, if you decide to run the plastic spur gear, you will need to sand it (the spur gear) to the same thickness as the steel spur and you won't be able to run over a 45t with any conversion but the tekno conversion.
