Ryu James
Ryu James's Avatar
07.23.2009, 07:34 PM
Hi Ryan, since you bought that box at radioshack, it includes a metal and plastic top, right? If you remove the water cooling bits, you can thermal epoxy the esc to the metal Case top, then epoxy a large heatsink to the other side of the top.
yes, that is right. it has both a plasic top and an aluminum top. however, after working on it today it appears the stock rampage rx box is gonna work better. it is slightly larger and will fit both my esc and rx comfortably and will be easier to mount. the RS box was just too tight of a fit. it would have looked real clean though. plus, with the rampage box i will be able to water proof it i think, even though the esc is already water resistant.
ha, i just said "box was too tight of a fit."
Jammin SCRT10 Neu 1512 1y
