07.23.2009, 10:32 PM
Is it the voltage cut off or is it the over current, over voltage or over temp protection? Do you have the com+ module to hook up to computer? You could try race mode to eliminate the current and voltage protection (USE AT YOUR OWN RISK). I do believe that the MGM has a 150,000 rpm limit with two pole motors, which would be a 75,000 rpm limit for a 4-pole.
