Motor Mount dimensions -
07.24.2009, 01:27 PM
Maybe this is too complicated to explain. Change title to "motor mount dimensions" I have another project in the works that requires a similar setup.
Here's what I desire:
Height of each motor mount (measured at the flats)
Distance of each center hole (either off-set or distance from edge)
Is it possible thay are all around 2" high?
The mounting bolt centers and size ar of secondary importance. This may be good info used in combo with the slipperential.
Thanks.
