Originally Posted by BrianG
Are you sure the DE does this? I don't remember seeing any other device on those BECs that would do as you describe. It would be a nice feature though.
I was specifically warned about the failure mode you described mode by Snellemin...you don't want a BEC that fails by passing full voltage because you will likely lose all electronics...but I will let Snell speak for himself...I bought DE based on his recommendation.
