quark125 li-po setting?
BADBOY2
quark125 li-po setting? - 07.25.2009, 01:57 AM
im reading my manual for my quark125.there are 2 choices :
Li-Poly High ● ● Select when the Battery is compatible with the voltage in use. Faster throttle response time and increased torque compared to when Li-Poly Normal is selected.
OR
Li-Poly Normal ● Select when the Battery capacity and discharge rate are lower than voltage in use. Slower throttle response and lower torque than when Li-Poly High is selected.
which of these settings u guys normally use?
the batts are 5000mah 2s1p 20c 7.4v turnigy batts.and im running them in series.
