JThiessen
JThiessen's Avatar
07.25.2009, 11:44 AM
sounds like you didnt remove the red wire on the esc's radio plug
remove the wire and the lvc will work fine, and yes it is your batterys are the real problem
No, that's not supposed to be done on the the Novak - or, if it was, Novak omitted this step from the "single pack" wiring instructions.
Originally Posted by whitrzac View Post
the novak BEC does not like 4s on one side...
That's the purpose of running the Rx pack.
Did you do the "turn the esc switch on, then back off" when you first turned it on?
Also, this should be in the Novak forum - NovakTwo will tell you to email customer service with a detailed account of what is happening.
