zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.29.2009, 02:37 PM
Why not just a label that states the packs Ri, that will tell us most of what we need to know right there in one simple number, much better than a C rating obviously.
EDIT: and a simple discharge curve at various C rates, with clear defined grid zoomed in on the graph lines.
Also a C rating should be really based on temperature though, it should be a predefined average voltage under load. Because some cells are different dimensions, which would for a given temp, one pack might have a higher/lower voltage under load because of a different heat dissipation level (cooling area)
