MetalMan
MetalMan's Avatar
07.29.2009, 11:32 PM
depends on the tooth count. I'd check http://www.sdp-si.com/ for 8mm pinions
SDP-SI does have them, but if you're planning on running a steel spur think twice about your decision, whether it be the motor or the spur gear.
So if you run a plastic spur, then by all means pick SDP-SI! I have an 18t steel one from them, and a 16t stainless steel gear. The quality is excellent.
