Thread: 60C really?
Finnster
KillaHurtz
Finnster's Avatar
07.30.2009, 09:14 PM
If it wasn't so absurdly expensive, I would get this pack and test it in the same CRT.5 setup as I tested the zippies and the Neu 30C packs.
What is odd is that this battery looks exactly the same but the ratings are different (and seems somewhat arbitrary.)
Pack #1:# 2200mah Capacity
# 14.8 Volts
# 34mm X 99mm X 32mm
# 25C Constant(55 amps)
# 35C Sustained(77 amps)
# 60C Burst(132 amps)
# 220 grams
Pack #2
# 2200mah Capacity
# 14.8 Volts
# 50C - 1620 surge watts(110 amps)
# 220 grams
Both for $115ea. >_<
Which would be the more fair pack to test against do you think? I have an Eagletree and a radar gun to get real world figures as well.
It wouldn't be fair to compare against the 30C 2500 Neu pack, but the zippy pack I already have data for, and its last years zippy-h's anyway.
Neu pack #1:
NEU2100XP 4S1P
NEU2100XP 4S1P 14.8volts
1C Charge
25C/50C
$44.00
or
Neu pack #2:
NEU2100EP 4S1P 14.8 volts
1C Charge
30C/60C
$60.00
